What is recommended repair for a stripped hole? "Click" to Login or Register
Picture of William Chappell
posted January 11, 2007 21:49
I'm working on an old Pocket Watch and the balance cock screw hole in the pillar plate is partially stripped. The screw will not fully raise out of the hole when unscrewed. But, the screw threads are fine. I'm thinking blue Lock-Tite, but first came to the board for their thoughts.
Thank You, Bill
Posts: 30 | Location: Mountain Top, Pennsylvania USA | Registered: November 20, 2005
posted January 12, 2007 08:36
From a mechanical standpoint that should work.
But first, you might want to see if any of the other similar screws in the movement might be ever so slightly longer. A longer screw may give you an additional "bite" that could help in this situation.
posted January 14, 2007 09:13
Bill,
I have had good results closing the hole a little with a round faced punch and making new threads. Be sure to pick a punch that is a little larger than the hole and give it a light tap with a brass hamner. Do this from the bottom side of the hole.
