Hello everyone, I was taking apart a 16s Elgin movement for a friend and when I pulled the dial I noticed a large area of the nickel had been stained a yellowish color, almost brass looking.
Can anyone enlighten me as to what the cause may have been and a possible cure to restore it back to its original condition. I do not have access to a camera at the moment and will post a picture later if needed. Thank you, Ray
Posts: 1499 | Location: Rancho Cucamonga, California USA | Registered: December 20, 2006
Ray, hard to say without seeing it in hand I often see watches with stained plates numerous things can cause it, sometimes as a watch fails to run, quick fix liquids and increasing amounts of oil added until it seems to run or stops completely are not uncommon sometimes I open a watch and have to lay paper towels on the bench to wipe my fingers on and catch the oil as it runs out while I disassemble, smoke of course can work in, complete movements are dipped in home made cleaners often to effect a clean also cause havoc inside. I would say if you do not intend to fully disassemble the watch I would consider leaving it as is the dust/fluff cleaning residues may well be worse than the stain, once disassembled I always start with the most gentle cleaning method, simple hot soapy water often worked wonders, if not professional jewelry cleaner in a ultrasonic tank up to non abrasive metal polish of which there are many. I prefer to stick to modern purpose made cleaners as opposed to trying anything under the kitchen sink, once removed wash in hot soapy water, rinse and dry completely before running through the cleaning machine as you don’t watch to transfer and contaminate the fluids.
Thanks Chris, I did soak it some of the L&R cleaning fluid I have with a light brushing and nothing. It still looks terrible, when time allows I will get a picture posted. Thank you again, Ray
That must have been some clean they did, wonder what they used, acid. I was expecting a few heavy brown oil stains. looking at the banking pins I bet the whole watch set up could be fun.
Hi It sure looks like it was gilded. However, there should not be any brass visible unless the nickel plating was also worn through. Could this be a case of too long time in the ultra sonic? Krister
Posts: 375 | Location: Backaryd, Sweden | Registered: April 19, 2009
