Hamilton regulator removalGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
What is the proper way to remove the regulator from the balance cock? This is on a Hamiton 992. Thanks, David | |||
David, when I do it, I remove the balance cock from the movement. I then remove the balance from the cock. Then, grasp the regulator with your tweezers under the arm as close to the circle as you can get and gently lift it off the balance cock. To place it back on, place the arm between the regulator spring and screw and gently snap it on with your thumb. Tom | ||||
