February 27, 2014, 13:48
Patrick WallinTwo piece Balance Wheel.
There has been a lot said about how to replace a staff.
Some just use a hammer and punch it out and others (Myself included) use a lathe to cut it out.
If you look at the posted picture of the wheel you can see that, at one time it was punched. There are no lathe markings (Circular patterns) on it.
The customer was upset because he "Just had it done last year"
Almost every book out there says to cut the staff out. I think most don't do it because it's easier to just whack it out with a hammer instead of taking time to set up the lathe or they don't know how to use the lathe, or don't have one.
I found and installed a different wheel and then checked it thoroughly be for I sent it back.
February 27, 2014, 15:54
Paul D. TrombleyTwo of those would make a real cool pair of ear rings.
George UlrichI'm a believer, bright side you can still use the weights
February 27, 2014, 15:56
Peter Kaszubskihere we go again
It was not watch maker by long shot that did that to a balance wheel it was a blacksmith or butcher perhaps shoemaker.
February 27, 2014, 16:17
Eugene BuffardIt is almost like religion. Tired of hearing about it. I think he was a shoemaker also. Thats was funny Peter!
February 27, 2014, 17:26
William D. WhiteI think it was done by a demolitions expert!
February 27, 2014, 20:45
David AbbeMaybe while cutting out the old staff his cutter 'slipped" and hit the wheel rim. I have seen the results of that before and it looks a lot like this, plus you have to look all over for the cutter. I had one watch where the last owner tried soldering the wheel back together!
February 27, 2014, 21:13
Peter KaszubskiFire in the hole ! kaboom staff been replace
February 28, 2014, 10:58
Brian C.The hairspring pin looks very nice as well.
