July 22, 2015, 20:15
Bill MandersElgin with stuck case
Hi,
I've got this 18s Elgin, what it is is unknown as I cannot get the case open.
It is in a swingout case, but it does not move when I pull the stem out, I actually pulled the stem right out of the case, and it still did not open up.
Any suggestions,
Bill
July 22, 2015, 20:54
Peter Kaszubskiscrewdriver under the cut to lift it or use some paint thinner/10W40 on cotton stick under the swing out ring .
July 23, 2015, 22:33
Bill MandersPeter,
I had been trying the method you advised, and finally I did get it loose, and open, with considerable prying.
Thanks for your help.
Bill
P.S. It is a gr.337, 3Fb, 17 jewel adj, 16s not 18 as I mentioned
