Hair spring question
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/4113901887
July 19, 2016, 11:18
Gene Nall
I need to raise the outer coil on this small carriage clock without raising the collet as in the beginning of the breguet over coil. I am wondering if there is special tweezers /tool for this or special means to do this?
Gene Nall
July 20, 2016, 08:18
Chris Abell
HI Gene,
just hold firmly with normal tweezers where you want the bend and press down into something firm like rubber, flip over and repeat, that will give you the step you require, then form as needed to make over coil meet pins and stud.
www.Abellwatchmakers.com
July 20, 2016, 10:09
Melvin Siedman
Hi Gene,
I sent some scanned pages to your email address from Fried's book that might be informative.
Let me kow if you get them.
Mel
