Mainspring Identification
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/331000226
January 16, 2004, 12:56
Kevin Pestor
I bought a lot of mainsprings, they are in the aluminum containers that hold them.Nothing is on them as to size.Is there a way to find out what they could fit without removing them from the containers?
I know this is a newbie question but i am a little puzzled.
Kevin "Veritas" West
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
January 23, 2004, 00:04
Brian Watson
No part numbers?
If you took one of them out of the aluminum you could classify it by your own measurements either take with a Dennison MS gauge or a micrometer. With the type of spring end along with the measurements we should be able to get you something to work with anyway. Without a part number or anything you're going to have to remove at least one from containers as far as I can tell.
B
January 23, 2004, 03:59
Brian C.
To all Chapter 185 members,
Be very careful buying parts without part numbers and when ordering from catalogs, be sure part assortments say for pocket watches or you can bet the parts you receive, will be for wrist watches.
Brian C.
pwpartsetc@pwatch.com
January 23, 2004, 10:54
Kevin Pestor
Thanks Brian, i have bought things and they had no numbers on them, like the springs, so i guess i have to take each spring out to identify it.
Also but some stems, they were ww stems. Confused
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
