July 01, 2003, 09:56
Kevin Pestorultra violet light
where would some get a light to cure the glue when you put in a watch crystal ?
Kevin West
July 01, 2003, 10:38
<Doug Sinclair>Kevin,
If you can find a small ultraviolet "Gro-Lux" lamp, that will work. They should be available from greenhouse supply outlets. Even a "Gro-Lux" fluorescent bulb that will fit into an available fixture, available from the same sources, or any store with a comprehensive selection of light bulbs. Or outside on a day that is not cloudy is what I use. Simple, cheap, universal.
Doug S.
