Does anyone have a chart that I can use to measure a pivot size vs. the metric or inch equivalent. I have a nice set of Mitutoyo calipers that I can measure accurately with but I don't know how to convert to "hole" size or "pivot" size. I need this so I can accurately order a balance staff. I can't seem to find a gauge anywhere to purchase. Thanks! David | |||
I may have answered my own question - the top measured .11mm and the bottom measured .09mm. I'm assuming that would be the pivot sizes. Now - when you order a staff they only give one pivot size - would that be the cock size hole or the bottom hole? Thanks again, david | ||||
Oh - by the way, this is for a burlington/illinois 19j getty model 16s balance staff. If anyone knows the part number that this would be, that would be helpfull. Thanks! David | ||||
I would expect that the bottom pivot is worn down to .09--unless someone modified it. Also,the lower pivot would be excessively loose in the jewel. I don't recall if any balance staffs had different pivot sizes, but if so, someone here will probably know. Sam Williamson | |||
I agree with Sam. The bottom pivot is likely worn down unless the lower jewel was replaced at some time with one with a smaller hole. The "Swigart Manual" lists two staffs for the models 4 & 5 (Getty) #47606 and #47609. Below are the dimensions of each from a chart posted some time ago by John Duvall. Hope this helps you ![]() Kenny ![]() | ||||
In my haste the headings in the above chart are misaligned. The last four should be shifted over to the right but since it is a gif image rather than text I can`t edit it easily. ![]() Kenny | ||||
This diagram may make it a little clearer. ![]() Kenny ![]() | ||||
Thanks!!! ![]() | ||||
