Hi all, have a Seth Thomas with a broken set screw in the regulator spring. Looking for either a decent replacement, or even the screw as I'm sure I can get whats left of the old one out. Some previous owner thought a shim of wood would do the job. I have removed the regulator spring for now as the watch itself runs very well. Thank you, Roland. R. Glenn ![]() | ||
Its an 18 size model 5 with 15 jewels. I've seen this regulator spring on similar models (pictured here), but just need this part not the whole movement. Thanks again, Roland. R. Glenn ![]() | |||
Here are the dimensions of this regulator spring that I'm looking for. It's actually quite small compaired to even the ones used on some railroad 16s movements. So if even I can adapt a regulator spring from another manufacturer including Swiss movements that would be great. Thanks again, Roland. R. Glenn ![]() | |||
Well just to follow up on this. I found a regulator spring/whiplash that fits, but isn't a Seth Thomas part. It's from a 16s Ball Record. The 2 mounting screw holes actually lined up. The only thing is that the hoop is a little large. So, still looking for the right piece. Maybe a whiplash off a Swiss, Illinois etc 14s will fit. Any ideas or leads appreciated. Roland R. Glenn ![]() | |||
