DIAL REPLACEMENT Subject closedGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
When replacing an enamel or porcelain dial that is pinned, how do you do it to make it stay without causing hairlines or worse? Thanks. Patrick 1616 | ||
I'm guessing you don't have the pins. If that is the case you can purchase Brass and or steel pins. You might have to install them in a pin vice then file them down. Then trim them to fit. Hence the word Watchmaker. | |||
