Need Movado 405 Teardown SheetGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a troubling Movado 405 on my bench. This thing has been torn down obviously before. Believe there is a gear missing in setting assembly. I would appreciate a exploded view of the setting components. Can someone help? Jeff Crawford | |||
Can you post a picture of the setting mech and plate? | |||
Chris At present this watch is torn down and in a divider tray. I was hoping that i could source an exploded picture of the setting assembly. As it sits now there is really very little that you can see. I believe that there is possibly a small eccentric gear that is missing? Date and day set but not the time. Looking carefully at it there seems this gear is absent between 4 different meshing gears. It is an overly complicated set mechanism. Jeff JJ | ||||
As a followup I diagnosed the problem but I have another. This is the post I placed on the national message board: I have a Movado 405 on my bench that I have found the problem with. The problem I face now is that I have no tech sheet on this watch and can not get one. This is a newer 36K B.P.H. with an offset 2nd wheel/pinion ***'y. On the opposing wheel end is a combination double gear time train drive and intermediate setting wheel. the double wheel is a friction fit ***'y on the 2nd wheel arbor. This double wheel ***'y is bad. I do not now if it is available as a specific part or is it part of the entire 2nd wheel. I have a list of available parts from my supplier but am unsure of the eb. pos. number or of its designation name. Can someone supply me with a tech sheet or at the least tell me the correct position number or designation name, of either this friction ***'y and/or the 2nd wheel ***'y? The supplier shows no 2nd wheel. Jeff Crawford JJ | ||||
Hi Jeff. You have me confused there, when you say 2nd wheel are you talking about the wheel that carries the “second hand” and therefore calling it the 2nd wheel? A picture of the movement/gears in question would help, is it a center second sweep driven from this “double wheel” then to a intermediate wheel feeding to the sweep second shaft pinion.? If it is what I think you are referring to the 4th wheel, and this “double wheel” is the 4th and the other gear is the “wheel over the 4th “ that picks up the intermediate to drive the sweep, when you say bad, what do you mean lose? Bent, teeth gone? | |||
