Advise needed on a lathe motor. ( Received ) "Click" to Login or Register
I have managed to pick up an 8mm lathe but without a motor.
Can anyone give me advise as to the speed and power requirements of a motor for such a lathe.
Posts: 575 | Location: Walsall in the United Kingdom | Registered: December 19, 2013
Picture of Billy Kuhn
Mike do you have 110v in the UK?? All US lathe would be 110V. I have a motor for a watchmakers lathe.
Posts: 1012 | Location: Killen, Alabama in the USA | Registered: January 15, 2013
Hi Billy, were all 250v over here. I would have to buy a transformer and they're heavy lumps. Also to ship a motor from the US would cost me a fortune. Thanks for your offer though.
I would be interested to know the detail on your motor plate so that I could source the correct type.
I have been looking at sewing machine motors but I saw somewhere that a 1/2 hp motor was used on a lathe and that seemed very high powered.
I really need to find the correct spec.
The lathe motors I've seen are typically in the 1/10 HP range. I'd look for sewing machine motors in the UK--they should work fine.
Posts: 995 | Location: Pleasanton, California in the USA | Registered: September 22, 2012
Picture of Patrick Wallin
If you try to do any lathe work that a sewing machine motor won't handle then you are overloading the lathe. You should be able to find one in the UK or perhaps a motor from a large floor fan. 1/10th HP and up will do the job.
Picture of William D. White
I would recommend a small brushless DC motor with a compatible BLDC speed controller.
William
Thanks very much to the folks that have replied.
I think that I now have enough information to start looking for the correct motor.
I really do appreciate the help which I receive from you all in this club.
