September 24, 2014, 18:28
Patrick WallinHere we go again [Question about oil for jewels and pinions]
oil?
If you do COAs and work on watches what do you prefer for oil for general purpose. A good oil that will work on jewels and pinions as well as other small items in the movement?
I have stem oil and a satisfactory grease but need a lubricating, lasting oil for moving parts.
September 24, 2014, 19:32
Serge BarlasHi Patrick,
Glad to see that you're on the mend and ready to get back to the bench.
My preference is to use Moebius 8000 oil for all the pivots and escape wheel teeth and I use NYE fulcrum clock oil for all other moving / rotating parts. This combination has worked very well and I have had no issues with any watch running "dry".
Now how much oil to use in which location is a question I'm still trying answer!
September 25, 2014, 18:00
Patrick WallinThank you Serge.
I have a very small tube of the 8000 and will use it. I can't imagine oil drying up after three months but it did. Dryer that a popcorn ****. I have been using a Moebius MS grease for a long time and have had no problems with it. Will be shopping for the 8000 in a larger quantity.
September 29, 2014, 13:02
Rafal WolerHi Patrick,
For my watches I use Ethsynta 1-3 (replaces oils number 1, 2 and 3 - Im not sure if you are familiar, but that numbering is popular in Europe, different number different purpose) for all except keyless work or main spring. For those I use Moebius 8200 (replaces oils 4 and 5). Both oils works pretty well and no need for buying all 5 separately. But that for pocket watches only.
Rafal
October 03, 2014, 13:51
Patrick WallinRafal,
I will check into the availability here in the USA. Sounds OK to me.
Thanks
