Split-plate advantages revisitedGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
(I hope this’s the right forum for this question!) Michael Harrold (American Watchmaking, p. 44) says that split-plate movements, though more expensive to produce than fullplates, were easier to work on and thus more popular with the trade. Would that statement be just as true of split-plate movements like for example the Elgin 16S Model 3 or the Hampden 16S Series I with concealed crown- and ratchet- wheels? | |||
Stu, From a repair standpoint the three finger models such as the Elgin 16s model 6 or 9 are easier to work with. Basically because you only have one pivot to line up per plate. If you just want to replace or work on one particular wheel it is easier to remove the one plate rather than disassemble the whole watch as in a full plate. Also the full plates and watches with more pivots per plate can be a little tricky and more time consuming to reassemble as it isn`t real easy to get all the pivots lined up correctly to go under the one plate. The two finger models with exposed winding is a good compromise and preferable to full plate since the click is more accessible to let down the power. Kenny | ||||
I recently cleaned and oiled a Bond Street keywind, full plate movement. These are difficult to asemble, first off upside down and the fit is not great and it was a 7 jewel.I will try to avoid these in the future.I have asembled other full plates upside down and much easier than the Bond.It is my freind,s watch, so i told him no problem i would clean it for him.Surprising this watch runs great after very little wear on it. | ||||
Dog, The bridge design of the Elgin 16s, model 3 is an easy movement to work on. Mainly because it's lever set. It's classified as a 3/4 plate or could be called a "split plate" I guess. Personally, I can assemble a full plate movement much faster and easier than many of the Elgin 3/4 plate models. Kenny, Although the Elgin finger bridge models appear to have seperate bridges, it's just one bridge with three screws and can be a bear to install sometimes. | |||
John, Thanks for correcting my mistake! I just chose a movement, in haste, that I thought would emphasize my point of; "the fewer pivots per plates the better". A speedy reply does no good if it is inaccurate. Another case of what happens when we "assume"! Kenny | ||||
Kenny, I used to think they were seperate also! | |||
Kevin, I concur completely with your experience on the Bond St. These 16 and 14 size that are a complete plate are a bear to reassemble. The books call them a 3/4 plate not a full plate. The Waltham 6S model 1889 is another example. If you think the Waltham was difficult, try a NYS of the same layout. They are even worse. Tom | ||||
