Hamilton 090 in melamine or is this a reproduction?....
August 17, 2013, 16:02
Robert EpsteinHamilton 090 in melamine or is this a reproduction?....
Was there a Hamilton 090 in melamine or is this a reproduction?....I recently picked this dial up:
"It's like deja vu all over again..."
August 17, 2013, 17:50
Robert EpsteinDid I post this in the right place?....
If not will a moderator please move to more appropriate place....
August 17, 2013, 18:07
Edward L. Parsons, Jr.It's no mystery, it should be in Hamilton. That's why we created the major pocket watch company forums, to keep EVERYTHING from going into Pocklet Watches.
So if you are discussing a Hamilton,Illinois, Ball, etc. pocket watch, that's the forum where it sould be discussed -- mystery solved.
August 17, 2013, 18:20
Robert EpsteinEd is this a legit dial?
August 17, 2013, 18:26
Edward L. Parsons, Jr.The dial looks OK, it's one of those made in both enamel and melamine.
August 17, 2013, 18:28
Gerald ZimmermannNot Ed but yes:
Hamilton dial 090-3 was melamine (and had a red 18)
look here Regards
Gerald
August 17, 2013, 18:30
Robert EpsteinI didn't know that it came in both versions.....
When I researched it under the heading "Hamilton 992, 992E, and 992B Case & Dial Identification. (1924-1971)" it didn't reflect that it came in both unless I read it wrong.....
Should this be added to that heading?
August 17, 2013, 18:33
Robert EpsteinThanks for the link Gerald....
I picked this dial up thinking is was the real deal....
Ed thanks for the clarification on where to post...
August 17, 2013, 18:43
Edward L. Parsons, Jr.Like everything else, you have to piece the clues together after the fact. The inescapable conclusion is that the designation "Dial 090" was used on both enamel and melamine dials.
August 17, 2013, 18:58
Robert EpsteinAnother new thing I learned today and just another reason to value being a member here....
August 18, 2013, 19:30
Richard RomeroRobert,
The descriptions used in the Hamilton 992, 992E, and 992B Case & Dial Identification (1924-1971) post is shown below. On the right in the box inside the box you’ll notice the letters DS, SS, P, and M and what they stand for. Now, if you look under Type the 090, 525, and 082 dials were produced in both Porcelain-Enamel and Melamine. What’s interesting about the 090 is the 18 is black on the P dial and red on the M version. Your dial looks to be in great condition.
Enjoy,
RR
August 19, 2013, 20:55
Bill MandersHi all,
This is a great post. I am wondering where the above info in the last post comes from, is it actual Hamilton records, is it from observation, or some other means? It definitely sheds a light on a lot of the dial questions I might have had, thanks for posting.
But where does it come from ???
Bill
August 19, 2013, 22:21
Larry LamphierBill, Thanks to Richard Romero it is right here on IHC185 under the "Hamilton 992B Research Forum"
Hamilton Dials Regards,
August 19, 2013, 22:47
Bill MandersLarry,
Thanks for the help, and a Thank you to Richard for all the information in that research. I am sorry That I sometimes forget how to use the tools at hand, as generally I do know that the info is here sometimes.
Thanks again,
Bill
August 20, 2013, 20:27
Larry LamphierGlad to help Bill.
I just use it all the time, so I knew where you wanted to go.
September 04, 2013, 03:43
I just edited the dial ID post so it should be easier to identify both versions of the 090 dial. There has also been confusion about the 525 dial versions so hopefully it’s easier to differentiate them now.
Here’s the new post:
992B Dials in Porcelain-Enamel and Melamine 525, 090, 082...
Bill,
That description above is stuff I typed, cut, copied, and pasted together. The numbers and descriptions are conclusions reached from Hamilton advertisements, catalogs, parts material lists, and blue prints as well as observations. Hamilton changed dial numbers and descriptions throughout the years so the 992, 992E, and 992B Case & Dial Identification (1924-1971) post is merely a basic guideline meant to identify and describe.
While doing the post Lindell and I had conversations about some of the dial descriptions and during that time I think he was also talking to Ed Parsons about the information and what the most appropriate description would be for certain dials. The end result is what we as collectors can presently use to explain to each other what dial we’re looking at and approximately when it was used.
Thank you Gentlemen,
RR
