August 18, 2014, 21:03
Claude GriffithNeed help with a Swiss Elgin
Most of the Swiss Elgins, excluding the Burens, are 17j marked unadjusted. I found one marked 21j with 5 adjustments, heat/cold/iso and 2 positions or heat/cold and 3 positions, not sure which. It was cased in a later base metal case with the typical train on the back but I had an NOS Elgin Cased and Timed case that was made for Swiss Elgins so I popped it in. It was missing the stem to begin with so that was something I would need anyway but I wondered if anyone had one of these Swiss Elgins with a gold filled trashed case but a good stem and crown?
Usually they are marked 956, 324, I don't think the 755 will work because it is a French movement nor the 657.
August 19, 2014, 07:02
Bila WirriganwaltersClaude could you possibly show a picture of the movement so I can see which plate layout it has?
Cheers,
Bila
August 20, 2014, 01:29
Tom DunnBila; Here's my Elgin 324. It's in an Elgin 4006 case. And has an ETA/Unitas movement. My "go to" carry watch.
