IDENTIFY MOVEMENT
https://ihc185.infopop.cc/eve/forums/a/tpc/f/2291010082/m/2421059581
May 23, 2006, 16:51
Daniel M. Weiss
IDENTIFY MOVEMENT
Could any member identify this high-grade 16 size movement with a clamp on dial, jeweler's name on movement and dial.
May 23, 2006, 17:27
Sheila Gilbert
Can you tell me what the name is? I can't read it.
Sheila
May 23, 2006, 17:35
Daniel M. Weiss
YES...Z. J. Peguignot, Philadelphia, PA.
SWISS, 21j Serial #25042, name is on movement and dial
May 23, 2006, 17:59
John Pavlik
Daniel,
Not sure of the maker.. Does this movement have 3 case screws??
May 23, 2006, 18:34
Daniel M. Weiss
YES! If you had looked a little closer you would see the third screw is not tightened against the case edge. I could probably find some identification if I took off the clamp on dial...but I thought one of our members might recognize the movement.
Could it be Aggasiz (spelling?) The regulator set-up looks familiar.
May 23, 2006, 20:29
Dave Coatsworth
Agassiz would be my guess, although Patek, Philippe also used Wilmot's regulator. Search the archives for "wilmot" and you'll find a bit more info.
May 23, 2006, 20:44
Anthony Crisci
Are you sure that G in Peguignot is not really a Q as in Le Cerneux-Pequignot Le Locle ?
May 25, 2006, 09:31
Daniel M. Weiss
While the name is in fine script my 50 years in the Graphic Arts industry enables me to distinguish between a "q" and a "g"...NO the the g is a g.
Thanks for your asking...example...Weiss...I have seen as Weiz, Weis, Wice and one or two others I may have no memory of.
May 25, 2006, 12:02
Anthony Crisci
I am sorry if I offended ,the photo is too poor to try and make out and I merely put the question because I had found references for watchmakers named “Pequignot” . I too can read with some slight skill acquired through the years but it was the abilities of the movements engraver as well as the idiosyncrasies of penmanship of the era which I was questioning more then your ability to distinguish the letter Q from the letter G. Good day to you.
May 28, 2006, 14:07
Daniel M. Weiss
If my reply offended you, I'm sorry...I only meant to say the signature is spelt with a "g" and not a "Q."
Sometimes, our wording can lead to a misunderstanding...it was not my intention to
infere my ego may have been taken to task.
Please do not feel put out! I'm like a pussy cat,
gentle and loving.
