June 26, 2012, 21:52
James ShuttsHelp with a Geneva seal pocket watch. Lester Cerf.?
I just purchased this 14k gold Swiss pocket watch. It is unmarked, except it is stamped twice on the movement with the Geneva seal. No maker or serial number. The dial is marked Lester Cerf. N.Y. & the dial side of the movement is marked 22478 which matches the case numbers. Very high grade movement with wolf teeth winding wheels. There are only a handful of watch brands that bear the Geneva seal. Any idea as to the maker of this fine watch?
Thanks, Jim
June 26, 2012, 22:27
Martin WagnerIf you google Lester Cerf there's some info about him being a jeweler.
Marty
June 28, 2012, 12:33
Dan CarterBHJ Co. shows up on some internet searches as a watchmaker. I did not want to post the link since it was an auction site. Try "bhj & co watch" in Google search. Similar looking movement and parts.
The G on the case stands for Geneva, and the Squirrel means 14K gold (as marked):
http://en.wikipedia.org/wiki/Hallmark#Switzerland.
Last search pulled up this - B. H. J. Co. (Bernard Haas Jeune Cie) as the possible watchmaker.
June 28, 2012, 21:12
Dan CarterI found this as well ...
Name of Company - Haas Neveux & Cie.
Year Started - 1848
In - Geneva
By - B. Haas Jeune
From -
http://www.antiquewatchworld.c...h/html/watch_co.html
