December 30, 2009, 13:50
Perry HowardAmerican Waltham parts is it worth restoring
I have a American Waltham parts I would like to know is it worth restoring. I have a beautiful dail and I have dated it around 1895 or 1896. The writing on the dail T. J. Gibson Winnsboro TX. Here are some pictures
December 30, 2009, 13:53
Perry HowardHere is a picture of the movement
December 30, 2009, 13:54
Perry HowardHere is a picture of the parts
December 30, 2009, 13:55
Perry HowardI have not case so I would have to buy a case.
December 30, 2009, 17:42
Richard M. JonesI would say no to restoration unless it has some personal value to you. You can buy a similar movement for $25-50.
December 30, 2009, 18:37
David AbbePerry the contract dial for an early Texas (Winnsboro?) Jeweler is a +++++ "extra" for that period model 1883 Hunter cased Waltham. At best your movment part have some value for but lack enough material to be worth restoring. eBay should have a Model 1883 Hunter Case watch for no more than $100.00 in good enough shape to restore and show off that neat dial.
December 31, 2009, 02:35
Perry HowardThanks both of u .I also have an elgin wheller 17g n6144515 in the same shape I am assuming it is not worth restoring .your apion would be grately apreached.I have very little money tied up in these so there wont be a grate los.I thank u alot for your inpout.Perry
December 31, 2009, 11:51
David AbbePerry, That dial deserves to "show" on a good working movement. It has real meaning and added value as a "collectible".
With that in mind, as the pallet fork and escape wheel seem to be there, please check the serial numbers on the balance wheel, plates and bridges, If they match the main serial number, it is worth a try to restore.
With a serial number match, if you want, send me those parts, I have many 1883 parts and can see what can be done with it.
As for the G M Wheeler, that started out life as an open face 15-17 Jewel Adjusted movement. The restoration value must be based on how many original parts are there. I would begin with the balance wheel, pallet fork and escape wheel as they are the matched up parts for it.
December 31, 2009, 21:02
Perry HowardDavid All the numbers seam to match if u would like to take a look I would grately apreachet if u would send your adress i would mail them to u and thank u again Perry
