February 06, 2013, 17:14
Walter Colkcolumbus question
I have a Columbus I think serial 79646 private label A.H.McIntyre portage la parie and Minnedosa. The date is around 1887 any help in id would be appreciated.
February 06, 2013, 18:02
Dennis McCannAn old history of Manitoba, Canada, published in 1906, says that Mr. Archibald Hector McIntyre was the leading jeweler in the town of Portage la Prairie, Manitoba. Son of a Scottish immigrant also named Archibald, this McIntyre Jr. (the jeweler) was born in 1857, moved to Manitoba in 1881, formed a partnership with a man named Davidson in 1882, then went into jewelry business on his own in 1886. Your watch movement definitely appears to be a Columbus. It would have been made in Dietrich Gruen's then-new, modern steam-powered watch factory here in Columbus on Thurman Avenue (about a block from where I live). I don't see an "adjusted" mark on your movement; I would guess it's a medium grade 18s watch, not intended for railroad use, but others may have better eyes than mine. I will not hazard a guess as to its number of jewels.
February 06, 2013, 20:09
Bruce ByrdWalter,
Yours is one of the few Columbus pocket watches that I have seen with a 24 hour dial.. Very nice example may I add
February 06, 2013, 20:59
Lorne WasylishenVery nice Walter! Was it a local pick-up?
February 06, 2013, 23:54
David AbbeThe Columbus Patent Micro-Regulator suggests this could have been set up to be positions adjusted by the Jeweler (if not already by Gruen). It is most likely a grade 33, and with that dial especially, quite a valuable collectible!
February 07, 2013, 11:55
Larry BuchanWalter:
I have posted on
page 2 of my Canadian Private Labels thread a Hamilton 18 size, 21 jewel, Grade 940 private-label WH McIntyre Portage la Prairie Man. & Kamsack, Sask.
February 07, 2013, 12:17
Walter ColkThanks fellows, a puzzel solved. Lorne you missed it
. Now the only problem is the stem which is missing. Thanks again.
