Hamilton 993 dial vs 992 dial question
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/9513995987
April 20, 2017, 20:49
Elzie J. Williams
Will the dial from a 992 o/f fit on a 993 h/c movement so that the numbers show correctly?
Jack Williams
April 20, 2017, 21:05
Buster Beck
Absolutely , they interchange and will be positioned correctly.
They DO have to be either both 3 footed or both 4 footed to interchange !
regards
April 20, 2017, 22:36
Elzie J. Williams
Thank you so much, Buster - I thought the dial feet might be different - Thanks again!
June 16, 2017, 02:17
Harry J. Hyaduck Sr.
To my knowledge any 4 footed Hamilton dial will fit any 4 footed Hamilton movement either open face or hunting. Same is true with the Hamilton 3 footed version.
June 18, 2017, 07:50
Buster and Harry are entirely correct. Hamilton dials are the same for both Hunter and Open-Face Configurations. Be careful with the four-footed because they are very hard to find individually.
South-Bend also interchange but Illinois are completely different dials on the Hunter-Cased watches, that is true on most Walthams as well with the exception of the 1892 Model which if I recall correctly do interchange.
