March 30, 2006, 22:03
Desmond LundyI seek help with this Keystone Howard
This watch is in a lot I am liquidating for an estate - and I am uncertain as the model number and relative scarcity / desirability. Any help will be appreciated. Serial number 1246587, 23j, five positions & temperature imprinted beneath the balance. 41mm diameter dial
March 31, 2006, 13:05
Tom McIntyreThe mechanism is 12 size, but the pillar plate has been stretched to14 size as may be seen by the location of the seconds bit.
These are not by any means rare, but are less common than the 17J variety.
This example looks like it may have the ratchet wheel replaced.
Here is an old photograph of one from my collection. Mine is a bit later as you can see by the design of the regulator spring. You can click on the image to make it bigger.
