July 26, 2010, 15:01
Roger StephensSeconds hand not moving?
Have a Rockford 18s key wind that is playing tricks on me set it wound it with front bezel and crystal off everything went to ticking replaced bezel the seconds hand stops but the min. and hour hand continue,take off bezel seconds hand ticks away.Scrathing my head with both hands!!Roger
July 26, 2010, 15:48
Buster BeckThe suspect sounds to be a loose seconds hand that's fitting/riding/sitting a bit loose on the pinion
July 26, 2010, 16:00
Roger StephensThanks Buster and Lindell the hand must have been loose.I"tweaked"it and now it is running and has been for 5mins.problem solved.You guys are the best.Thanks Roger
July 26, 2010, 16:31
Buster BeckGlad to be of service as always
