December 15, 2010, 10:45
Brad Richardson992E Questions
Hi! I'm gonna just jump right in here with a question that I'm curious about (especially when I go to ebay). I know that Hamilton started using Elinvar in the 992 in the mid 30's. However, they discovered that it had some problems, so they made their own, Elinvar-Extra, which was far superior to anything manufactured to that date.After 1940, everything Hamilton produced used an Elinvar-Extra hairspring. My question is: since Elinvar-Extra is so much better than the first Elinvar, why are the 992E's commanding such astronomical prices? Some are absolutely rediculous!!
December 15, 2010, 12:27
Michael Logginsrelatively few produced compared to the elinvar extra equiped 992b or 950b.
December 15, 2010, 18:29
Brad RichardsonThanks, Michael, I appreciate it.
December 15, 2010, 18:33
David AbbeOne of the most Hilarous parts of the highly "secretive" (to watchmakers) "Elinvar" is that it was simply a High-Nickel Alloy that was originally developed for the Glass/Metal sealing pass through wiring used on Lightbulbs and Vacuum Radio tubes. The nearly "0" thermal modulus of the material made it an ideal "prospect" for watches as well. The "higher grade" made by Hamilton was more than likely more highly refined to reduce troublesome inclusions.
Going a little further, "Elinvar" was also "re-refined" into "Hi-MU" materials essential to the early developments of higher frequency Magnetic read/write heads which led all the way into the higher performing Rotating Disc memories that "escaped" that material only recently with Semiconductor Technology based designs.
December 16, 2010, 11:10
Larry LamphierBrad,
Hamilton made close to 550,000 992's and only around 61,000 Elinvar models. To most Hamilton collectors that will drive the price WAY up.
I only started into this about a year ago, and the Elinvar was the first thing that REALLY got my attention. That and the fact that most prople will pay a LOT more just to get one.
December 16, 2010, 12:41
Jerry KingThe 992E, marked Elinvar,with a GJS and Gold Center Wheel is a one * rated watch....which means 2500 or less made....
December 16, 2010, 15:12
Edward L. Parsons, Jr.That annotated page tells a big story Lin.
I agree, a brass center wheel is something I've never seen on a 992 Elinvar either.
