February 21, 2011, 16:15
Gary StringerCan this dial be cleaned?
I purchased an A Lincoln and the dial has this black residue that looks like coal dust. Is this a common problem on some dials or can it be cleaned? SN
3292702
February 21, 2011, 17:11
Roland GlennThat's right. Porcelain dials come up very nicely with Comet and a little soaking, but metal dials are very different and very delicate.
I have used dish soap and a gentle touch and have had good results, but I've also had absolute disasters where the numbers have rubbed right off.
So like Debbie suggests, a refinish might be the only way to bring back that roaring 20's look.
Roland
February 21, 2011, 17:22
Gary StringerThanks, it likely is a painted metal dial. It just looks so strange with being almost clear in the center that I was not sure what had happened to it.
February 21, 2011, 17:38
C. Keith JohnsonIf your dial is metal chances are the cost to refinish would be close to the cost of a replacement if you could locate one.
Run a search on "International Dial" located in Wilmington, Ohio and you will get some information....Keith
February 21, 2011, 19:15
Gary StringerKeith,
Thanks, I'll go search them out now.
