Waltham Cronometro Victoria
January 08, 2011, 12:11
Tom BruntonWaltham Cronometro Victoria
a lovely Waltham Cronometro Victoria movement with gold jewel settings ,gold movement screws ,and gold case screws. It is running and keeping time but needs a COA. Does anyone know how you tell if this is 15 or 21 jewel? Is the 21 jewel marked,and not the 15? thanks,Tom
January 08, 2011, 12:14
Tom Brunton#2
January 08, 2011, 12:15
Tom Brunton#3
January 08, 2011, 12:24
Buster BeckI would think since the center wheel is not jeweled this would be a 15J watch.
January 08, 2011, 12:27
Jerry KingThe Waltham database says it is a 15j, mdl. 1899, Hunter....
P.S. It also says the grade is "Export"
January 08, 2011, 12:45
Tom Bruntonthank you very much Buster and Jerry
January 08, 2011, 16:50
Hub HarmsHi Tom,
Escape wheel& pallet don't look to be capped with jewel,no jewel on center wheel.Probly 15 jewel
Start: End:
First: 11132501 Last: 11133500
Model: 1899 Name:
Material: U Grade: Export,
Size: 16 Size: 16
Plate: 3/4 Plate:
Jewelling: Jewels: 15
Balance: Bal: Pat. Reg. - Breg. HS
Style: HC Style:
Htg.
Hub.
January 08, 2011, 17:50
Bill MandersTom,
They really are a decent looking watch, and they are listed as a 2 star in Shugarts, for what thats worth.
Here are some pics of one I have.
Bill
Bill Manderscase: They've lied about this one, it is not 14K
January 08, 2011, 17:51
Bill Mandersmvmt: ser# 9846908
January 13, 2011, 13:00
Tom BruntonBill Manders
IHC Member 1153
Posted January 08, 2011 17:50
Bill ; I was looking at another friend's Chonometro Victoria which has a movement signed Waltham ,not Chronometro Victoria, but it has what looks like a fancy designed and coloured Chronometro Victoria dial,perhaps an O'Hara!!
. What is interesting is that this case is marked Victoria 14k ,however the pawn shop that had it acid tested it on the outside face of the hunting case and there is a 1/2" circle dead center burnt right down to the brass!!
January 13, 2011, 13:09
Bill MandersHi Tom,
I had never seen a movement not marked as a Chronometro Victoria, but in reality it is just an inexpensive 15j mvmt. All of the ones I have seen have been marked, with the sun emblem imprinted. The cases commonly apparently were made by Estrella, and this also has the sun emblem on it. I do not know how thry get or got away with the false gold markings, but was likely before laws had been passed.
Bill
January 13, 2011, 13:13
Tom BruntonYes a bit odd since the case is signed though a phony 14k , and the dial is amazing!!!
January 13, 2011, 20:26
Ethan LipsigI have a very pretty 14 size Cronometro Victoria that is in a solid 18k gold case. There's no doubt about that given how soft the metal is and how many dents I had to get removed.
January 13, 2011, 20:27
Ethan LipsigEnamel monogrammed cover
January 13, 2011, 20:29
Ethan LipsigFogel 18k marking. Fogel was the company that distributed Cronometro Victorias.
Ethan LipsigFancy Cronometro Victoria dial
January 13, 2011, 20:34
Ethan LipsigMovement
January 13, 2011, 20:36
Bill MandersEthan,
That is really a WOW dial and case, which movement is in yours ?
There was obviously different dials, hands,cases, etc. depending on what the customer wanted,
Tell you what I will trade you if you want ??????????
Bill
I was obviously typing as you were posting, it's interesting that yours does not have the sun on the movement.
January 15, 2011, 19:00
Robert SchusselIf my memory serves me correctly these watches were for the export market in South America.At least in 16 size both the movement and dial should be marked. I am less sure about the case.
