July 12, 2011, 11:29
Donald NicolaiQuestion on winding mechanism of Waltham model 1883
Good morning all,
I have a 1892 model 1883 size 18 that will set hands but not wind. When taken apart I found 2 pieces of spring, that if it should be one piece, would be in the shape of a barbell. It appears this spring would move the gears back and forth to wind or set the movement. Hope my explanation is correct and helpful. Failed in my attempt to send a photo.
Thanks for any help, Don
July 12, 2011, 13:48
David AbbeThe The Model 1883 Waltham 18s "Barbell" (I call it 'Dumbell') is fragile indeed. The hardness varied so much that some collapse after time and others break like glass. I have one (pictured below is it
) you can have if that is what you need. Please confirm your address to me at;
david@glopar.com
July 12, 2011, 16:48
Donald NicolaiDavid,
Thanks for the part & thanks for the picture. This shows me exactly how it should be installed.
Many thanks, Don
July 15, 2011, 16:04
Donald NicolaiThanks Dave,
I received the "Dumbell" spring in the mail today.
Don
