Need Help With Hamilton Dials & Hands
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/8683962677
December 17, 2012, 13:08
Donnie Tackett
Hi,
I am looking at a 972, 16s dial from a 85xxxx (1912) that the movement is no good.
Will that dial & hands interchange with a 16s, 992 748xxx (1909). Confused
The 992 has a 4 foot dial and I assume the 972 (being a pre 872000 serial#) would have a 4 foot dial as well ?
Donnie T. Smile
December 17, 2012, 15:26
Jon Hart
Donnie,
I believe the four foot dials should interchange...
December 17, 2012, 16:05
Jon is correct,
Hamilton dials with the same number of feet do interchange.
December 17, 2012, 16:13
Donnie Tackett
Will the 972 dial 16s interchange with the 992 dial 16s?
December 17, 2012, 18:08
Donnie,
You only posted partial numbers but assuming they are numbered below the 872000 area both should be four-foot dials, in which case the answer is yes. Same holds true for the three-foot dials, they will also interchange with each other, that is why we sometimes see a 1946 movement oddly fronting a 1916 dial.
