I need help from an Elgin Collector (Mystery solved)
October 31, 2011, 14:48
Harry J. Hyaduck Sr.I need help from an Elgin Collector (Mystery solved)
I am starting to get into my Elgin movements to sell you know where so if anyone is looking for anything please let me know. I don't think I have anything highly collectable but I don't know. I don't have anything with more than 17 Jewels.
I have at least 3 G.M. Wheeler's that I am going to list. They all have good balance staffs and the balance wheel swings freely on all but only one runs a little and stops.
I was trying to see what the price guide book value is but I can't find it. I think they are 12s. I see two in the price guide and they are both adjusted to 5 positions. All three of mine are adjusted to 6 positions. Are they listed and I'm just looking in the wrong place?
Harry
October 31, 2011, 17:21
Patrick WallinHarry, Keep me in mind. I am constantly looking for non - running watches to repair, polish up and sell to the bid & whine flea market. Or even running watches with problems. After your main sale if you have any left let me know.
Patrick 1616
October 31, 2011, 18:22
Harry J. Hyaduck Sr.Hi Patrick,
I will keep you in mind. I'm still trying to figure out how to quit losing money on the you know where site. When I bought these things long ago I had no intention of selling them so it did not matter if I paid near dealer price for them. I had to quit starting them at 99 cents because that was all anyone would bid for it and with all the fees I was losing money. To make money you need to buy right so you call sell and make money. I did not buy right because I had no plans on selling. My fault.
Now in order to buy what I actually collect I have to sell. I was forced to retire three years ago and with no cost of living raises I am taking home about 7 to 10% less than when I retired.
When all the dust settles I'll try to remember you want the left overs but try to jog my memory every now and then.
That is why I'm trying to find out about the 6 position adjusted Wheeler's to find a price to start them at. It I start them at 99 cents that is probably all I'll get and I'm not letting them go for that. The price guide only list 5 position Wheelers and a search here did not turn up anything.
Thanks for your interest,
Harry
October 31, 2011, 23:49
David AbbeHow about a list of the serial numbers.
November 01, 2011, 05:49
Harry J. Hyaduck Sr.Certainly Dave, s/n 26810896, 23967026, & 25035945. Let me know if you need photos. I need to take photos anyway to list them.
Harry
November 01, 2011, 10:59
David Abbe26810896; Size 12, 17 Jewels, Grade 452, 1 of 69,000 c.a. 1923
23967026: Size 12, 17 Jewels, Grade 452, 1 of 69,000 c.a. 1920
25035945; Size 12, 15 Jewels, Grade 315, 1 of 1,033,900 c.a. 1922
Photos of case, movement and dial condition are all important
November 01, 2011, 11:55
Harry J. Hyaduck Sr.Thank you Dave,
The information on two of the movements appear correct. 25039545 is not 15 jewel though it is 17 jewel. They all are marked "SIX ADJUSTMENTS" stamped on them under the "17 Jewels". The price guide shows adjusted 5 positions. I will take some photos in a while and put them up so please check back in a few hours.
Harry
November 01, 2011, 12:02
William D. ShieHarry, 6 adjustments is not the same as 6 positions, If I recall correctly 6 adjustments = 3 positions, heat and cold and isochronism.
Bill
November 01, 2011, 13:29
Mark CrossThat's how I've always understood it too, William.
Harry, are they marked '6 adjustments' or '6 positions'?
It makes a big difference.
Regards! Mark
November 01, 2011, 14:16
Harry J. Hyaduck Sr.Hello Bill and Mark,
Now I'm really confused. The Wheelers are marked "SIX ADJUSTMENTS" and in the price guide they are listed as "Adj. 5P". I am reading that as "adjusted 5 positions". Am I wrong?
Thanks
November 01, 2011, 14:54
Buster BeckI think one may need to zoom in really close to the "Adj. __ Positions". I never met a 12sz Elgin that was adjusted to 6 positions, but I would think there may be some since I'm not a very sharp cookie on Elgins.......
Adjustments are a different story, and could include isochronism, heat, cold and "X" number of positions.
5 Positions alone marked on a watch would indicate that the watch is timed to keep time face up, face down, pendant up, pendant right, and pendant left. Most higher grade watches including RR's are timed to 5 positions with the exception being 6 positions and that final 6th position would be pendant down.
With that being said, a 5 Position watch would have 8 Adjustments, and a 6 Position watch would have 9 Adjustments.
Your first & second posts mentioned "positions", then your 4th post mentions "adjustments".
I would feel fairly confident that the GMW's are Six Adjustment's : [ Isochronism/Heat/Cold/3Positions ] I would think the Price Guide has an error in it on most all of the 12sz Elgin's in stating "5 Pos." The price guide is as stated, only a price guide, it has many "positional errors", if you will
And as always, pictures are worth a thousand words.
November 01, 2011, 15:02
Harry J. Hyaduck Sr.Here are a few photos
November 01, 2011, 15:05
Harry J. Hyaduck Sr.Front
November 01, 2011, 15:06
Harry J. Hyaduck Sr.close up
Buster BeckThey are marked "Six Adjustments"= isochronism, heat, cold, and 3 positions.
Since marking the movements, "Six Adjustments" was a marketing ploy, it would stand to reason that they stated "all" that they could, however I suppose it could be argued that it refers to Isochronism/Temperature/4 Positions, or even, Isochronism/5 Positions, but then they would of put "Eight Adjustments" on them
So I feel secure with 3 Positions [ dial up/dial down/pendant up ]
November 01, 2011, 15:12
Harry J. Hyaduck Sr.Thank you Buster for educating me once again and for clarifying the price guide. Now I know the difference between adjustments and positions.
Harry
November 01, 2011, 15:59
Edward L. Parsons, Jr.This is something that should be flagged for suggested edits to the 2012 Price Guide. That's something we provide to Cooksey Shugart every year.
November 01, 2011, 16:38
William D. ShieYes it seems that Elgin used this as a marketing ploy to make it seem like something it's not. I'm not knocking Elgins; I'm a big fan but it does seem deceptive to me.
Bill
November 01, 2011, 16:41
Harry J. Hyaduck Sr.I agree. However I do not know enough on how to flag it but if someone will tell me how I'll be glad to do it.
Harry
