February 08, 2011, 20:15
Theodore J. Brown Sr.Nice 940 Claude! I was almost blinded by the bright plates.940's are a great watch, even better with that Montgomery dial...Ted.
February 08, 2011, 21:31
Tom BrownI agree with Ted, very nice.  I also like the Montgomery dial.
This past weekend I serviced my 1st 940 with the motor barrel, I thought it was interesting how that is installed & removed.  I should have take a photo.
What is the serial number on yours Claude?
February 08, 2011, 21:49
Samie L. SmithClaude that looks like a nice one these are very pretty movements..
Tom the motor barrel setup on these is different from most Hamilton,s with the 2 screws holding the barrel assembely they are easy too work on.
February 08, 2011, 22:21
Claude GriffithSerial Number 990,120, I think that put it in the 1912-13 range. The case is a triple hinge, isn't marked but doesn't appear to be brass so I guess it is gold filled but not sure how many years. Someone broke off part of the second hand and mis-matched the screws but other than that it is in good condition and so far keeping good time.  I guess just for extra measure it is my second case that has a big elk on it.
February 08, 2011, 22:45
Claude GriffithJim I got it for a bit below low book, it cleaned up well and I didn't figure a second hand a correct hold down screw would set me back that much so I splurged.  The case is in very good condition, little wear, so someone babied it.
February 08, 2011, 23:35
Tom BrownSamie, that was what I thought was neat about the motor barrel in these, I had not ever seen one held in like that before, I thought it was unique.
February 09, 2011, 13:34
Chris HughesVery nice! I have two 940s (both fully marked versions) that I really love.
February 09, 2011, 19:27
Norman MayberryI have two very nice 940's that are in "glass back "cases that previous owners made up by adding bezel and glass to the back.What style case did these actually come in?Thanks in advance for your help.Norm
February 09, 2011, 20:06
Edward L. Parsons, Jr.Norman,
A glass back or display case version can be made of any case for which you can locate a second bezel.
Back in the day, watchmakers also used to create display cases by chucking back covers in their lathes, cutting out the center portion and then cutting a groove the correct size to accept an appropriate glass crystal.
