August 07, 2011, 11:22
Theodore J. Brown Sr.Removing a glass crystal
I probably should have posted this in the repair section, but here goes. Is there a safe way to get a glass crystal out of a bezel without breaking the edge?I have a junk case with a nice crystal, and I want to use it in another one.I thought of maybe turning the bezel around in boiling water without getting the glass in it until it falls out.Anyone have any ideas?
August 07, 2011, 11:24
Eugene BuffardCleaning ammonia should loosen the glue up. Just soak it for a while.
August 07, 2011, 11:36
Roger StephensTheodore,I just removed one by placing bezel and crystal in pretty warm water for about 30mins.might give it a try.I am sure the ammonia would work also. Roger
August 07, 2011, 13:08
Theodore J. Brown Sr.Thanks guys, I tried the hot water method, and it came right out with no damage.Take care, Ted.
August 07, 2011, 13:29
Eugene BuffardI clean my case's in Household amonnia and Simple Green. Every time there is a Glass crystal in a case I have to re-glue it in place. I use 2 part epoxy to hold my pocket watch crystals in the bezels. I'm not sure if hot water will soften epoxy glue.
August 07, 2011, 13:46
Theodore J. Brown Sr.Gene, do you use a clear epoxy, or the kind that looks grey?I know they make that UV cement that's supposed to work good.Thanks, Ted.
August 07, 2011, 18:12
Roger J. NolfeCrystal Adhesive - G-S Hypo Cement. Made for the job. Inexpensive and can be ordered from many online sources.
August 07, 2011, 18:46
Chris AbellFor most I use the UV crystal glue with fine needle applicator, a single thin bead around the entire bezel is needed if you set it well under UV light 10-20 minutes will stay there without problem and come out again if needed with a little pressure under two thumbs or if you need to save the crystal boiling for a short time will soften most glues.
August 07, 2011, 19:48
Edward L. Parsons, Jr.Call me old fashioned, but I go by my watchmaker's advice: a round pocket watch glass crystal of the correct size will stay in just fine by friction alone. If you need glue to hold it in, it's too small.
I've always done my glass crystals that way and have never had a problem. However, I have had problems trying to remove crystals that someone glued.
A friction-fit crystal is a lot easier to remove!
August 07, 2011, 20:27
Eugene BuffardI use the 2 part clear epoxy. I have a uv light and the uv cement. I had a few crystals that did not stay in correctly. Maybe I did not leave it under light long enough.
I have never had a problem removing a crystal. When you are cleaning the case the way I do. The crystals fall right out.
August 07, 2011, 20:47
Theodore J. Brown Sr.The one I took out had no traces of glue, I submerged only the edge of the bezel and kept turning it to evenly heat just the bezel, and it came right out.Like Ed said, this was really tight by friction alone.Thanks to everbody, Ted.
