ID on an Illinois 12 size
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/8313935477
September 12, 2012, 18:58
Brad Richardson
Hey all. My cousin has an Illinois 12 size that I'd like to identify for her. It is "The Autocrat", serial number 4434325. Any info on this one? Thanks. Regards, Brad
September 12, 2012, 19:11
Jim Bielefeldt
I usually recommend the pocket watch database. But sometimes its a little off.
http://pocketwatchdatabase.com...ois/4434325/movement
It says its a 12s bunn special lol.
Ruby Jewels
Movement Serial Number:4434325
Estimated Production Year: 1923
Run Quantity: 1000
Jewels: 17j
Movement Finish: Nickel
Model: 3
Movement Setting: Pendant
Plate: Bridge Plate
Barrel: Going
Adjusted: Yes
Adjusted to Positions: 6
Railroad Grade: No
Notes: Center Bridge Plate Design.
But the numbers for the info look right, except the adjustments. I like Autocrats. The signed cases are a plus and the movements are easy to work on.
September 12, 2012, 19:15
Brad Richardson
Thanks Jim. This one is in a base metal Keystone case, with one of those crappy plastic replacement crystals that is beginning to turn yellow. The movement looks good, but the dial has those ugly age spots here and there. Regards, Brad
September 12, 2012, 20:02
Jim Bielefeldt
Those age spots are common. I think Illinois sold more 12s painted dials than ceramic. At least thats what it looks like to me from all those I have seen. Still the movement is a good one if taken care of.
