New Here Couple Questions - Elgin with Ferguson Dial
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/8261016881
June 06, 2006, 13:06
Ryan Scott
Hello,
I am new here. I have a pocket watch that was given to me by my grandfather. I have no information on it except i believe it was his fathers (i think) but i do know it has been in the family for a while. Here are my questions.
1. Is there a way to tell when it was built?
2. What kind of case would it have been in?
3. I would like to get it running again. What steps should i take?
4. I know ferguson Dials are sometimes valuable what kind of vaule would be assigned to this watch?
Here are the pictures. I know the dial has some issues but that is the way i got it for the most part.
June 06, 2006, 13:09
Ryan Scott
Sorry the quality is bad. I have better pictures but they are large.
June 06, 2006, 13:19
Wayne C. Anderson
Ryan,
If you can provide the serial number on the movement it would help in identifing your watch. Smile
June 06, 2006, 13:24
Ryan Scott
Okay here is the serial number...
17035389
15 jewels
Thanks.
June 06, 2006, 13:32
Wayne C. Anderson
Your watch was made in 1912, its a grade 312, the size is 16, and it was designed for a hunter style case, and it has 15 jewels. There are several members of 185 that do watch repairs. To find a case is also easy, put an ad in the wanted section. Good Luck Smile
June 06, 2006, 22:18
Samie L. Smith
Ryan other than the balance parts for the Elgins can be found most of the time..
The Ferguson Dial on a hunter case movement is not something you see very often..
June 07, 2006, 10:33
Ryan Scott
Thanks for the replies. I am looking forward to getting it running again.
Can you explain what grade 312 means?
So what case exactly should i be looking for? An Elgin Hunter 1912?
June 07, 2006, 17:20
Sheila Gilbert
Ryan,
You need to downsize your pictures. It actually makes them worse sometimes, and we can't see the details. Next time, make them a little smaller.
Welcome to IHC 185!!!!!
Sheila
June 07, 2006, 18:49
Wayne C. Anderson
Grade numbers were originally used by watchmakers to identify movements for repair parts.
Today they are mostly used to identify the quality of a movement. Smile
To house the movement in you would need a 16size Hunter style case.
June 08, 2006, 18:09
Ryan Scott
I am going to take some better pictures.
March 12, 2009, 08:51
Ryan Scott
Hi. Long time no post. A lot has been going on but i have some updated photos.
I would really like to get this running again. If you know of anyone that does let me know or you can email me. Thanks.
March 12, 2009, 12:41
Edward Kitner
Ryan,
I would personally recommend Chris Abell. He posts here often and is a master watchmaker.
http://www.abellwatchmakers.com/
March 12, 2009, 13:21
Ryan Scott
Thank you. I emailed him.
March 24, 2009, 10:31
Ryan Scott
Got in touch with Chris. Thanks.
