Interesting Hamiltons from Orlando!
February 25, 2005, 20:36
Jim HanieInteresting Hamiltons from Orlando!
This is a 992 that there are 4 know to exist. I know who the owners are of the other 3.
February 25, 2005, 20:38
Jim HanieCheck out this one.
February 25, 2005, 20:41
Samie L. SmithWow Jim what nice watches,,That 947 is a beauty..
February 25, 2005, 20:42
Jim HanieSeldom seen 991 in Gold Case. I think the production numbers and actual numbers are far apart on the 991. Only actual examples will tell the story.
It is marked but weak or my lighting is off.
February 25, 2005, 20:44
Jim HanieDial for the 991
February 25, 2005, 22:15
Terry HillCongrats on the Inspector Standard....
and
THANKS for letting me hold the others in Orlando.. I was 'shook up' when I found I was holding the 947... the watch is so much more impressive in person..........
February 25, 2005, 23:15
Charles R. SidesWOW is an over used word, but
W O W !!!
Thanks for sharing these special watches.
February 27, 2005, 14:30
Harvey J. MintzHmmm! I think I object - that picture of the 947 doesn't do it justice!
Try this one:
February 27, 2005, 17:11
Ed UeberallHere is one of my finds fron the Orlando Regional. This one will hold a special meaning for me, as it came from Mike Laux's collection.
I would love to get additional information about any Hamilton movememts that shared this damaskeen pattern. The serial number is 527,733. It's a Grade 940, marked "Adjusted 5 Positions".
Ed Ueberall
IHC Member 34
The Escapement
February 27, 2005, 17:15
Ed UeberallHere is the dial on the Hamilton 940 shown above.
Ed Ueberall
IHC Member 34
The Escapement
February 27, 2005, 17:34
___________Jim - Love this Orlando "finds" thread, and thanks for showing each of these. Might be attracting some more Hamilton collectors to FL next year!
Ed - Great looking 940 and I much appreciated your showing this one to me at the show. I don't have many serials on 940's with this damaskeen, but here are the few others I do have in my notes ...
524913 (just marked "Adjusted", no "5 Positions")
554418
591713 (no "940" marking on barrel bridge, also factory markings oriented differently)
693412 (private-label marked)
And I have just about this same damaskeen noted as being on ...
547337 (grade 926)
624021 (grade 936)
... so looks like one could assemble a nice little collection among the movement variations found with this damaskeen pattern.
Fred
February 27, 2005, 18:59
Terry HillThanks Ed for posting the 940.... "what a bargain"?
I was looking thru notes to see if I had any others......
I had only marked your example.... before you obtained it......
Here is one thing I picked up off of a table full of watches.....
February 27, 2005, 19:03
Terry Hilland a different view of the movement....... It is a
lever set 974 by sn
February 28, 2005, 12:51
Jim HanieTerry,
What a nice watch. One never knows what is out there. It make a 974 into a rare collectable watch.For your research I have one with that pattern 783,713.
Congratulations!
ED,
That is a great sunburst pattern. When I looked at that watch it was $500 higher than you bargained for it!
Some others for your data base.
680,124 a 924 Mine
591,713 a 940 on Ebay
502,301 a 940 Jim Walz
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/5196015554/r/1316045364#1316045364February 28, 2005, 19:09
Ed UeberallIn addition to those serial numbers posted by Fred and Jim, we have the three additional numbers in our database, so the complete list so far:
512515 Adjustment marking not noted
515631 Marked "Adjusted"
524913 Marked "Adjusted"
527733 Marked "Adjusted 5 Positions"
527737 Marked "Adjusted 5 Positions"
554418 Marked "Adjusted" not marked "940"
591713 Not marked "940"
693412 Marked "Motor Barrel" private label for
Fred StraubSo it appears we have identified a number varients;
With or without "940"
Marked "Adjusted" or "Adjusted 5 Positions"
Marked "Hamilton" or private label
Marked "Moror Barrel"
And, this is with only 8 examples.
BTW, I have 502301 listed as a Grade 926 with a "Hamilton Special" dial, rather than a 940.
Ed Ueberall
IHC Member 34
The Escapement
March 01, 2005, 03:09
___________Terry - I have 738249 and 783487 down as being similar "fishscale" type pattern 974's.
Fred
