October 12, 2013, 12:15
Brian C.Keystone Mainspring Number needed
Does anyone know the white alloy, mainspring part number, for an 18s Keystone Watch Co. dustproof model? Thanks.
October 12, 2013, 13:32
David AbbeBrian, I am working on a dustproof now and replaced the mainspring from my stock with a white steel "Super Security Brand". The package label reads;
        802
   21 x 1-1/2 x 20
       T-END
     FAC #2190
      18s NYS
This works fine in the s/n331779 dustproof I am restoring
October 13, 2013, 12:10
Brian C.Thanks Dave,
 I have two other company white steel mainsprings and the packages say, M/S #2190, 20x1x20 T end. Was the spring you took out of the Keystone a 20 or 21 wide? I haven't taken my watch apart yet.
October 13, 2013, 19:13
David AbbeBrian, I did not mike the width so it was whatever came out of the bag. If you have a white steel that is 20 instead of 21, that may be all of .2 mm (0.008") narrower and should work fine.
October 14, 2013, 13:14
Brian C.Thanks Dave, I figured it would be fine, if I wind up needing a mainspring.
