July 08, 2013, 22:55
Kevin MoodieMore Patina
I recently acquired a Hampden KW watch in a VERY dark case. The case is a Fahys SENIOR coin pair case, with a nickel inner unit (except for the pendant, which is silver). A pretty 11j movement which runs. I thought $70 was a reasonable price.
July 08, 2013, 23:37
Lorne WasylishenNice case!, I like silver patina. I just passed up a very patinated sterling case on ebay.
It went for $97 even though the seller couldn't get the covers off.
You did OK considering the ABP on your watch in the Fat Book. I assume you looked your watch up
HERE.
July 09, 2013, 13:06
Richard M. JonesKevin you did very well. The case alone is worth $100 or more in my opinion.
July 09, 2013, 13:13
Jim BielefeldtI think it might be worth more if the oxidation and dirt were cleaned off of it.
July 09, 2013, 13:23
Andy Schwartzpatina on a hamilton or illinois watch dial - very desirable. patina on silver, not a value adder. clean that case and the 100.00 is very accurate. I love the blue screws, great buy!
July 09, 2013, 19:45
Kevin MoodieThanks all for the input. I will probably clean it up at some point, but it's soooo black and shiny, like my old mans 1940's Lincoln Zephyr.
I did clean up the last silver case which was an Edgemere "sidewinder". Even the gold was tarnished. A bit of wd-40 and rubbing with paper towel got it clean without removing any of the overlay.
July 09, 2013, 21:45
Ethan LipsigAndy, you say that patina is very desirable on Illinois and Hamilton dials, and adds value, but what do you mean by "patina." I have rarely seen an aged dial that I found attractive. For example, does the dial shown below (on a scarce Illinois Grade 438 movement) have value-enhancing patina? If not, I would be grateful if you posted an example of a patinated dial that is more desirable than one in essentially new condition.
