Dripping oil
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/7463927657
December 18, 2010, 12:58
Jim Bielefeldt
Dripping oil
Hi,
I have noticed that a few watches that I have gotten lately are just coated in oil. One BW Raymond actually dripped oil when I got it out of the case.
For awhile now I take apart every watch I get to clean, oil correctly, and adjust it. But can this oil bath they receive before I get them do any long term harm? If so I wonder how to spot it in pictures to avoid it.
December 18, 2010, 21:03
Gary E. Foster
JIm, I guess it depends on the type of lubricant,Though I've read some types, such as WD40, will contaminate your cleaning solution.
December 18, 2010, 22:58
Jim Bielefeldt
Thanks for that info. Since I dont know what was used if I run into any more like that I think I will clean the parts twice so as to remove as much as possible. I dont use a lot of cleaner in my little setup on each cleaning so its not a great loss. Better to be safe than sorry.
December 19, 2010, 11:26
Bill Goff
WD-40 has shown to be a poor choice for a lube. The Ct. State police had a few failures from the lube drying and jamming the gun. Nothing surprises me about the 'Bay any more.
December 19, 2010, 11:58
Edward Kitner
I just finished cleaning a pvt label getty model Illinois that was absolutely filthy. Someone had sprayed what I believe to be WD 40 all over the mvt. It was even between the top plate and the bridges. Surprisingly it was running when I received it!
December 19, 2010, 12:12
Mark Cross
Amazing. EekWD40 was never intended to be used as a true lubricant in the first place. It was crated to displace water, hense the 'WD' in it's name, 'water displacement'. Of COURSE their guns jammed! Roll Eyes
Regards! Mark
December 20, 2010, 13:32
Bud Melless
Hi Bill;
We too found it to be unusable as a lubricant. It also freezes at temperatures below -5 F.
I've seen Semi Auto's and Revolvers jam up solid in the winter time up here with WD-40 in the works
Bud
