Question about Movement -
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/7383941077
February 22, 2012, 14:10
Jon Hart
the book states this a "PS Bartlett"; however, it is not stamped on the movement as such. Was this common practice?
Did Waltham have many runs of this type of detail on the back movement plates? Seems like it would have been alot of work back then for just a 15j movement.
Serial # 4461552
Also, it states the following "Ch SW OF nickel PS P Reg BH"
Looks like there were 1000 in this run of production in 1890.
Any help would be appreciated
February 22, 2012, 14:19
Andy Schwartz
https://ihc185.infopop.cc/eve/f...86009181/m/844104342
MANY TIMES WHEN YOU RUN WALTHAM NUMBERS YOU GET xxxxx GRADE, WHETHER IT IS PS BARTLETT, WM ELLERY, STERLING ETC... I SEE IT ALL THE TIME.
Jared Brinker
Jon-
sometime the records are incorrect OR the run was actually split up into other runs also. South bend on more than one occasion made upjeweled movements of watches in different runs and made hunting and open faces grades in the same runs.
Jared
February 22, 2012, 14:26
Jon Hart
So, this is NOT a PS Bartlett 15j movement?
In the Swigart book it shows the first 1883 starting with movement # 2,354,001
February 22, 2012, 14:32
Jared Brinker
Jon-
No, it isn't. It is just a waltham 1883 model. It would be marked PS Bartlett if it were. It is a nice patternon the plates. It would probably bring more than a PS Bartlett one would anyways.
Jared
February 22, 2012, 14:39
Jon Hart
Jared -
This is the 1st Waltham I have run across with this pattern and was trying to figure out a ballpark value for it. Any thougths?
Here is the dial...
Seems to running well on my desk
February 22, 2012, 14:47
Jared Brinker
Jon-
movement only with dial, I would say around $50-$75. 1883's just don't have a good folowing unless they are something scrace and railroad related such as railroad king, CPR, etc. I think they just made too many of them and almost all were lower jewel count. I sold the last PS Bartlett movement and dial I had for around $35 with nickle plates. I had no problem witht he price because I typically only get around $75 for them cased in a silveroid case anymore on ebay and I have no extra cases at the moment to be putting movements in.
Jared
February 22, 2012, 15:03
Jon Hart
Jared -
Trying to weed out some of these 18s Waltham and Elgins. You are correct there are many of them out there.
Your 50-75 range was my thougths too
Thanks
Still wanna trade me that BUNN?
February 22, 2012, 15:10
Jared Brinker
Jon-
What do you have for good 18s hunting cases? could still use a couple over here! Buster had to step in and buy the really nice one you had. I think my 312 SB would have looked really nice in it! Big Grin
February 22, 2012, 21:06
Richard M. Jones
I agree with Jared, too many and not particularly valuable but the pattern is a real eye catcher. I believe that pattern also shows up marked non magnetic.
Deacon
February 22, 2012, 21:48
Jon, this watch is very nice!
My Walthem production record shows s/n 4461001-4462000 are 18s, Stem Wind, Pendant setting Model 1883, Grade No. 15, 15 Jewels, "A" grade material (probably 3 position adjusted) with a Patent Regulator, and Breguet Hairspring.
The P.S.B. models were produced in the 1000 pieces preceding production of your grade 15 and are about the same excepting they were Hunter Movements and Lever Setting.
Your unique plate finish is very well done Damaskeeening over acid etch which was referred to as "frosted finish". Given the hands, the very nice Hard Enamel/Glass dial and the fact that it is an open face movement, I would start looking for a nice long stem 1890's vintage open face case. You have a great "carry piece" of significant value when cased.
February 23, 2012, 22:42
Jon Hart
Thanks for the data - Sir...
Spot on again - my friend!
February 23, 2012, 22:53
Robert V. Jones
I have one of these with this design listed in a hunting case if anyone is interested.
tymekeeper005
