March 09, 2005, 06:11
Frank KusumotoMystery South Bend Unfinished Watch
A little pictorial of an unusual find at;
http://www.southbendhorology.com/movements/mystery/index.htmlVery strange indeed. Enjoy!
Frank "407" Kusumoto
March 09, 2005, 18:53
Sheila GilbertFrank,
OUTSTANDING! I'm green with envy!
Wish I could do that.
Thank you for sharing it with us.
Beautiful work.
March 09, 2005, 19:24
Tom HuberFrank, That looks like a watch that was smuggled out of the factory in pieces by an employee to be assembled and finished at home. All of the watch companies had security and checks in place to stop this, but it went on in every factory.
March 09, 2005, 21:12
Jerry TreimanWhen watch companies had movements that took a non-standard case they made "casing blocks" (usually solid metal) that they sent to the various case companies so they could make cases to fit the movement. The South Bend 12-size was certainly a movement requiring a special case. Perhaps this piece served as a casing block for this model, with the inclusion of setting mechanism and the ability to put hands on it to be sure the pendant was properly aligned and the bezel was high enough.
March 09, 2005, 23:43
Frank KusumotoJerry,
That's an interesting theory of the "casing block" and one I hadn't considered. It certainly makes sense. Explains the the keyless works and all the pivots/wheels for hand placement. Thanks for your comment!
