November 24, 2014, 18:28
Peter Kaszubskiwatch dial feet soldering machine.
https://www.youtube.com/watch?v=bW8foz8E0U8can be use on pocket and wrist watches dial
price is not that bad at all
November 24, 2014, 18:55
Patrick WallinNice find Peter.
Before purchasing I would ask, How do you know the new foot will be in perfect alignment as was the old? I may be interested.
November 24, 2014, 19:08
Peter Kaszubskiif the old one is broken you will see the spot
where it was and go from there.
November 24, 2014, 20:54
Lorne WasylishenLooks pretty good Peter, are you considering it or just looking?
What do you think a person would have to charge "per foot" to make it feasible?
November 24, 2014, 21:17
Peter KaszubskiI would use it with COA services if I see dial with missing foot but Im not doing COA for other ppl.Perhaps $10 to fix feet
November 25, 2014, 00:08
Mike HodgePretty neat machine. One member could buy it and fix all our dial feet for a price
November 25, 2014, 06:20
Dan CarterI bought one of these a while back as I had to repair a few dial feet and move others to fit different movements. It works. It takes practice but it works. I don't have any pics of the backsides of dials, but here is front side dial meant for a 2824 that I put on an dg8213). As for lining things up again, you really can't use the old spot where the foot was. You need to sand it down so the solder can hold. Needs to be flat. Best option is to make a template for where the feet will go. I tried soldering by hand but was not steady enough. FLUX is your friend too when you solder. Solder goes where flux goes.
