re: 18s 21 Jewel Bunn special
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/6863917877
June 08, 2013, 20:11
Bila Wirriganwalters
Would anyone be able to tell me the total amount of the 21 jewel 18s 6 positions Model 6 Bunn Specials that were made. The pocketwatch database says over 380,000 but that includes the 16s as well and I think there were many more of those made.
Thanks to All,
Bila
June 08, 2013, 20:31
Bila, My 2013 updated database reports 100 made total, all in one rn in 1895. They are pictured as Two-Tone and in the serial number range: 1285501-1285700. Evidently the actual numbers of 21 Jewel movements made were short of the total 200 serial numbers assigned.
June 08, 2013, 20:48
This one is up in the #166xxxx range David, yet to have it in hand. Thanks for the info.
June 08, 2013, 23:03
Bila, what is the full serial number?
June 08, 2013, 23:30
#1669847 Adjusted 21 Ruby Jewels,
June 08, 2013, 23:39
Edward L. Parsons, Jr.
David,
Every 18S 21-jewel Bunn Special made after about 1906 (movement numbers > 1.8 - 1.9 million) was marked "Adjusted 6 Positions" because time service rules were changed to require the number of positions to be marked, and these watches were all adjusted 6 positions. I'd need to do some research to find the exact number produced, but it has to be a lot more than 100 watches.
Before the rule change they were all just marked "Adjusted."
June 09, 2013, 00:07
Tom Dunn
Bila; Yours falls into a wide range, there's the 2 tone, bright spotted pattern, narrow pattern, circular pattern, sounds like you have the bright spotted fourth pattern, there were 6000 of those made according to the blue book.
Dave; Where can I get the database? I'd like to own one.
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
June 09, 2013, 01:03
Thanks David, Ed & Tom, this one has the bright spotted pattern.
Best Regards to All,
Bila
June 09, 2013, 13:15
Evan Patton
Tom,
I was wondering the same thing. I'll send you a link.
Evan
June 09, 2013, 13:22
Of that type, (bright spotted 4th pattern model 6) the database reports 4328 made in the s/n range 1278201-1730600 from 1895-1904 with yours made in a 200 piece run in 1903.
