July 21, 2012, 09:35
Mark G. ReitzSante Fe Staff??
Greetings,
Does anyone know what the proper staff is for a 16s 21j Sante fe double roller,ser #3466694,and is it considered a model 8 or 12 ?
Thanks,Mark
July 21, 2012, 10:47
Jim BielefeldtAccording to an
Online database its an 8th model. Cross referencing that with Swigarts American watch movements book the double roller staff would be 47607 also known as 1506/47633.
But since I am not an expert lets see if I got it correct before you order it.
July 21, 2012, 11:40
Brian C.quote:
3466694
Mark, I believe Jim's info is correct.
Brian C.
July 21, 2012, 12:14
Mark G. ReitzThanks to Jim and Brian for your input!!!I replaced a wobbly lower balance jewel but the balance is not seated with the cock in proper place so I am not sure if someone placed a staff too short or too much wear on staff
Mark
July 21, 2012, 12:34
Jim BielefeldtIts possible its the wrong staff as the correct one also fits the Bunn Special. Those staffs are sometimes hard to find. The 1684/47608 has the same dimensions except its shorter. 5.04mm instead of 5.32. If you have a micrometer it should be easy to check.
July 21, 2012, 16:35
Richard M. JonesMark I bought a box of staffs recently and 2 boxes of miscellaneous junk. The staff box is just great and as it happened the junk had 2 16s staffs for a Bunn Special in it and if you need one let me know.
July 21, 2012, 23:51
Mark G. ReitzI
Richard.....Thanks for your offer to help,Brian C. is sending one out.
Mark
