18s Dueber Watch Co. Watch Info Needed
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/5581006112
October 08, 2006, 11:42
Sheila Gilbert
Hi,
Any information you can give me on this one would be wonderful. Thank you!
Picture 1 of 3
DueberDial75
Sheila
October 08, 2006, 11:43
Sheila Gilbert
SN 677416
Dueberwks75
Sheila
October 08, 2006, 11:44
Sheila Gilbert
Fays Monarch 14k gold filled case
Dueberfays75
Sheila
October 08, 2006, 21:27
Tom Huber
Hi Sheila, Your watch is an 18S, 15J with a teske regulator. The SN puts it at mfg of about 1889. Although your case is marked 14K, it has the look of a gold filled case, and I believe that all the Fahys Monarch cases were gold filled. I'm sure that other experts can comment on this.
One good screen technique is to close the cuvette (dust cover under the back cover), press gently on the center of it with your thumb. If it gives slightly, it is solid gold. If it has no give to it, it is gold filled.
October 08, 2006, 22:16
Sheila Gilbert
Tom,
Thank you for your information.
I did know about the case, and that the Monarch was most likely gold filled, however I also noticed the Teske Regulator, and I really liked the Unusual Dial, so I went for it. Paid way more than I should have, but sometimes you just get a nudge ya know?
Sometimes the most unsuspecting watch will just grab you. I also liked the idea that this one had the Dueber Watch Company on the movement and the Dial. I had not seen many of these either, soooo...........
Thanks again!
Sheila
October 08, 2006, 23:01
Tom Seymour
Very nice watch Sheila. Love the dial.
The book describes it as: 18s, 15j, open face,nickel, model 3, lever set, unadjusted, grade - The Dueber Watch co.
October 09, 2006, 01:52
Sheila Gilbert
Thank you Tom S. I liked that dial too!
Can you tell me if those screws are correct? look wrong, or just kinda not right to me???!!!
Of course, I don't know this watch either, so let me know, if you know, ya know!!!! Big Grin Eek Smile
hehehehe
Sheila
October 09, 2006, 21:33
Tom Seymour
Sheila,
Here is a similar movement to compare with yours.
November 14, 2006, 17:18
Mike Paynter
The screws are correct. Blue steel was used quite a lot on these.
November 14, 2006, 19:17
Sheila Gilbert
Mike,
I thought they were ok, just not real sure, and the one I actually wondered about is the silver one at about the 9:00 position. It didn't look right to me. ??????
What ya think?
Sheila
