January 01, 2010, 21:30
Edward KitnerHamilton 940 dial signatures
Hello,
Does anyone know the date or serial number when the dial signature on the 940 changed from script to the block style?
Thanks
January 04, 2010, 10:07
Edward KitnerEven an approximate date will help!
January 04, 2010, 11:26
Tom BrownEd
I know I have seen the answer here somewhere before.
Check out this one & see if it helps.
https://ihc185.infopop.cc/eve/f...151019671#6151019671Tom
January 04, 2010, 12:25
Edward KitnerTom,
Thanks for the tip, that is what I was looking for. I have to learn to think out of the box on these search engines
January 04, 2010, 18:56
Edward KitnerLin,
Thanks to both you and Tom I now have a better idea of what dial, say a 1903 940 should have. Or If I am looking at a 940 made in 1919 I know what the proper dial should be. I also know with only movements being sold, then cased by the jeweler an original to the watch dial could be different. But the vast majority will fall within the specs you and Tom have shown me.
