Illinois Ambassador, 2 tone movement..Help please ident??
December 17, 2007, 20:24
Keven CrutchleyIllinois Ambassador, 2 tone movement..Help please ident??
Hello.
I just received a very nice 12 size Illinois Ambassador 17 jewel, 2 tone movement pocket watch. SN # 3994613 (1922)
Could anyone help in identyfing this movement?
I have looked for a few days now and come up ith nothing.
Thanks in advance.
Keven
December 17, 2007, 20:26
Keven CrutchleyHere is the movement
December 17, 2007, 20:58
Stephan GaalI believe there should be a whip spring with an adjusting screw attached to the balance cock.
Closest I can see in my book is the "Maiden America" which looks similar. No doubt an Illinois collector could tell you more. I believe Illinois had more named watches than any other maker. Exactly where this one fits in I am not sure.
December 17, 2007, 21:03
Ray HallenbeckKeven,
Appears to be a nice looking grade 405 private label, circa 1922 or abouts.  I believe the grade 405 was a medium grade watch by the Illinois Watch Company.  Hope this helps.
Ray
December 17, 2007, 21:24
Keven CrutchleyThank you all so far. I didn't notice the missing whipspring and screw.
Thanks again.
Keven
December 17, 2007, 22:19
Robert SchusselKeven
About 20,700 serial numbers were reserved for the Grade 405 hunter and 380,000 for the open face . It was considerd a slightly higher grade than the 404 as it was adjusted.
Because Illinois had over 1,000 different private labels it is often impossible to know who the watches were made for.
Bob
December 17, 2007, 22:58
David AbbeKeven, There is no doubt in my mind that somone with an artistic flair working in Marketing at Illinois W. Co., had to have something like a "Watch a month club" going. The workmanship was spectacular! The presentations and names were an orchestra with endless varieties as unlimited as the imagination of the Damaskeening Machine operator. I am dropping in a pic of my "VIM which god knows why they did not follow with a "Vigor"! But it does show what the whip regulator spring looks like on these movements.
December 18, 2007, 00:10
Ray HallenbeckDavid,
 I'm with you on the various watches, grades,patterns etc of Illinois.  It is by far my favorite watch to collect as it seems that they all differ to some extent and there are many to choose from.
Ray
December 18, 2007, 00:16
David AbbeRay, I know we digress but only ever so slightly as I must go on with the artistic "flair", What is the difference between a Model 1 and Model 3 12 size but the cuts in the3 plates? Evidenced by a highly damaskeened (wow) no-named 21j, and a 17j "Autocrat", from my humble collection. One a false brige and the other the "3/4 Plate" look, yet I venture they could be interchanged on the main plate!
December 18, 2007, 00:22
David AbbeThe false bridge "Autocrart, remains my favorite style as with Keven's rare looking 2-tone Ambassador. It has to be carried ONLY when the wearer is in a Tuxedo!
December 18, 2007, 00:31
Ray HallenbeckVery nice, and as usual I learned something new here as I never noticed the "False Bridge" on the grade 405.  I too have a 17j Autocrat like yours, it is serial # 3,041,503 but sadly is a movement only.
December 18, 2007, 00:44
Ray HallenbeckThis topic got me to looking at my 12s Illinois and I also found a grade 427 19j marked James A Garfield with # 3,932,175.  And a Model 1 grade 255 marked "Laclede".
Wow, love these watches.
December 18, 2007, 14:00
Jim CarrollGreat to see some size 12 Illinois.
Kevin,
A little more information, as your watch comes fron the run 3,994,001 – 3,996,000 = 2,000, grade 405 hunter it can be estimated that about 300 of these are Ambassador.
With the serial numbers I have, the breakdown of the run looks like.
3,994,444  Forum                     estimate of 500
3,994,561  Illinois Watch Co.  estimate of 100
3,994,666  Ambassador            estimate of 300
3,994,988  Sterling                   estimate of 100
3,995,824  Illinois Watch Co.  estimate of 1,000
From the records I have  Ambassador only turns up in this run in size 12 watches.
Jim Carroll
December 18, 2007, 16:45
Keven CrutchleyWow, thank you all for all your info.
I have not been on the website for awhile. There is so much knowledge here.
Thanks for the pic to see the spring I need to get.
Thanks again,
Keven
December 18, 2007, 17:33
Jim CarrollRay,
Is it possible to have the serial number of your Laclede Grade 255, the info I have Laclede turns up in only 3 runs of 1,000. There are only 4 runs of 1,000, the largest runs in this Grade.
2,974,001 – 2,975,000 = Laclede 1,000 estimate
2,978,001 – 2,979,000 = Laclede 1,000 estimate
2,981,001 – 2,982,000 = Laclede 1,000 estimate
Jim Carroll
December 19, 2007, 01:42
Ray HallenbeckHello Jim,
 The serial # on the Laclede is 2,978,091 which fits in with your numbers...Any idea of what the "Laclede" stands for?
Also, if you collect the 12 size Illinois serial numbers I can get the ones I have for you.
Ray
December 19, 2007, 10:40
Joseph T. CollinsRay,
Pierre Laclede was one of the founders of St. Louis, Missouri. There are many references to "Laclede" around here and the natural gas utility here is the Laclede Gas Co.
Since Springfield, IL is only 90 miles away that may have some bearing on the Laclede name.
Joe
December 19, 2007, 13:06
Jim CarrollRay,
Thanks for the serial number, with the low number helps to confirm with the other numbers I have that its almost certain that the 1,000 are Laclede.
There is another run of Laclede 2,074,001 - 2,074,500 = 500 grade 219, size 12 open face 11 jewels.
Joe could well be right about the origin of the name, the 255 runs are 1916 and the 219 run is 1908.
It would be great if I could have your Illinois size 12 names and serial numbers.
Jim Carroll
December 19, 2007, 18:30
Ray HallenbeckThanks Joe for the information on the origins of Laclede.
 Jim, I will write the serial numbers down and get them posted tonight.
Ray
December 19, 2007, 21:08
Robert SchusselIf people have any information I would be very curious about the Illinois "Stewart Special".
While a private label what makes them interesting is that most of the serial numbers are in the 4M but use the old style ebauche.
I have posted a few pictures in the past.
Here is a 19j hunter I just purchased with a serial number of  2881867 which is more typical what of this ebauche.
Bob
December 19, 2007, 22:35
Ray HallenbeckJim
 Here are the 12 size numbers I have and also some of which I have sold.
The Autocrat # 3,041,503 mod 3, grade 405
The Autocrat # 3,420,866 mod 3, grade 405
Illinois Watch Co # 4,364,406 mod 3, grade 405
Illinois Watch Co # 2,316,360 mod 1, grade 228
LaClede #2,978,091 mod 1, grade 255
Illinois Watch Co # 4,801,889 mod 3, grade 405
Illinos Watch Co # 3,571,600 mod 4, grade 404
Halmark Watch Co # 3,537,492 mod 4, grade 504
Illinois Watch Co # 4,051,111 mod 3, grade 405
James A Garfield # 3,932,175 mod 3, grade 425
Ray
December 19, 2007, 22:37
Ray HallenbeckRobert,
 Thats a beauty.  I may have a 16 size Stewart if you want the number I'll check.
Ray
December 20, 2007, 14:38
Jim CarrollRay,
Thanks for your serial numbers, If James A Garfield has 19 Jewels it will be a grade 427.
Bob,
Re the Stewart Special I have noted 23 runs in size 12 watches and I guess there will be many more the have not been accounted for.
 In grade 274 the grade that you have shown, has so many small 19 jewel runs there could be plenty of Stewart Special’s, here is the runs I have in grade 274.
1916 …2,881,501- 2,881,850 = 350   open faced.  Stewart Special
1916 …2,881,851- 2,882,000 = 150    hunter         Stewart Special (your serial number)
1918 …3,414,301- 3,414,400 = 100   open faced.  Stewart Special
1919 …3,566,401- 3,566,500 = 100   open faced.  Stewart Special
1921 …3,813,001- 3,813,300 = 300   open faced.  Stewart Special
1921 …3,843,501- 3,843,700 = 200   open faced.  Stewart Special
1922 …4,011,641- 4,012,400 = 760    hunter         Mixed run, J.H Ehrlich 21 J.  Stewart Special 19 J
1922 …4,053,001- 4,053,650 = 650   open faced.  Mixed run, Elbros 21 J.  Stewart Special 19 J. and
 Elite 21 J.
Jim Carroll
August 15, 2009, 20:03
Robert SchusselRay
I don't see your post although I have seen a question from you about the 15j grade 255.
The Grade 255 15j is very rare--estimates range from 50 to 100.  If you have a picture would you please post it
Bob
August 15, 2009, 20:42
Ray HallenbeckSorry about that Robert.  I deleted it because I was mistaken in the jewel count.  It's actually a 17 jewel..AND, I was wearing my glasses
 when I first checked it.
Ray
February 06, 2018, 12:19
Josh R. ArmstrongI need help 21j 3184848 3pos  especially for J. H
 Josh R. Armstrong
