May 21, 2004, 09:08
Wayne C. AndersonIllinois 12-Size info request - Marquis Autocrat
Would anyone have any additonal details about an Illinois "The Marquis Autocrat", motor barrel, Special Model 165? Thanks
May 21, 2004, 10:50
Jerry TreimanThe "Special Model 165" would appear to refer to the case, as we see the same notation in the 6-sided case on his A.Lincoln model (Faces N' Cases section).
May 21, 2004, 11:07
Phil DellingerWayne,
Using the serial number shown on this watch movement, here is what I found for your Illinois, " The Marquis Autocrat".
Ca. 1927 - Model 3XT - Grade 525 - movement description: Temperature, 3 positions, Ruby and sapphire jewels in raised gold settings, gold center wheel, double roller, patent regulator, cased at factory, pendant set, 17 jewels.
May 21, 2004, 11:11
Wayne C. AndersonThanks Jerry & Phil
Sent a copy of the dial/movement to Jim Carroll for his information.
