February 18, 2004, 15:56
Stephanie O'NeilIs this correct placement of watch parts on movement?
Is it possible for a center wheel to be sitting on top of rochet wheel and crown wheel and actually work? Doesn't look right and yet seller said watch is working. Maybe it's just me, I don't know. I really don't claim much knowledge regarding watch movements.
Take a look. Need your input please!
Stephanie O'Neil
Pocket Watch Moderator
NAWCC Member 143979
February 18, 2004, 16:02
Bernhard SchmidtIt shorely looks like the wheel sitting on top of the Hamilton 3992b, navigation master in the photogallery, but bigger, doesn´t it? What is that wheel for? Have seen similar on sertain grades of Omega wristwatches and others.
Bernhard "the swede"
February 18, 2004, 16:14
Stephanie O'NeilBernhard,
I checked out the 3992b in our Photo Gallery. Yes, somewhat similar, odd. Thanks!
Do others have any input on the movement in question as well?
Stephanie O'Neil
NAWCC Member 143979
February 18, 2004, 16:36
Stu GoldsteinIs it a center-seconds movement?
Stu
February 18, 2004, 16:38
Jerry TreimanIt appears that this must be a watch with a center sweep second hand. The center sweep arbor passes through a hollow center wheel arbor. The small pinion at the end of the sweep-hand arbor is held in tension by the small flat spring visible in the center. The pinion is being driven by the large visible gear that is friction fit on the extended arbor of the third wheel.
February 18, 2004, 17:00
Stephanie O'NeilStu & Jerry,
Yes, the dial has a center sweep second hand.
Jerry,
Then the wheel in question does make sense and is correct right?
How unusual are these movements? Do you see them often?
Stephanie O'Neil
***** Member 143979
February 18, 2004, 21:27
John D. DuvallSteph,
The picture you posted appears to be an 8/0 size movement. I have seen them described as nun's pocket watches and the same movement was also used for wrist watches around WWII.
Attached is a picture of my Elgin "Doctor's Watch". It was the first Elgin to use a center sweep seconds hand. Grades 83, 84 & 89 were made of this model in the late 1800's. Elgin also used this design on smaller movement grades 532, 539, 647, 685 and the WWII era 21/22J GCT pocket watch. Other watch companies have used designs similar to this.
Altough collectible, I would not consider any of these grades as rare.
John D. Duvall
Vice President, Education
February 18, 2004, 21:55
Stephanie O'NeilThanks John.
I've not heard of an 8/0 size movement.
Earlier, I was able to pull up comparible watches and discovered they are indeed nun's pocket watches.
Thanks for the info on center sweep second hand pocket watches!
Stephanie O'Neil
NAWCC Member 143979
