Washington Watch Co.
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/5273948877
June 18, 2013, 21:06
Peter Kaszubski
Is ther any info out ther on Washington Watch Co.?
I know watch was made by Illinois Watch Co.
I like to know total production of this watch
its size 16 mark Washington Watch Co.
Senate with s/n 2182320.
Thanks.
June 18, 2013, 21:14
Andy Schwartz
Grade: 175
Movement Serial Number:2182320
Estimated Production Year: 1909
Run Quantity: 50
Jewels: 17j
Movement Finish: Nickel
Model: 5
Movement Setting: Lever
Plate: 3/4 Plate
Barrel: Going
Adjusted: Yes
Railroad Grade: No
Notes: Possible Bridge Plate Design. Getty Model.
Andy Schwartz
Illinois Grade: 175
Grade
175
Total Runs
233
Total Produced
42,225
Start Year
1896
End Year
1912
June 18, 2013, 21:35
Peter Kaszubski
I do not think so Andy.
This one shows all 175 grade if you look at the Washington watch its bit different them 175 grade
as you can see on the picture.
I think ther was only around 500 ever made in this one finger configuration
June 19, 2013, 00:07
Peter, I agree with your estimate of 500 one finger bridge movements. Sadly, while many Illinois grade 175 movements were made, the very few 1 finger cut bridges should be better distinguished from the rest.
June 19, 2013, 02:12
Tom Dunn
Peter; That is a 1FB 175, they made 350 of the 16S 17J Senate in that grade. There were also 700 Grade 605s and 400 Grade 304s in the Senate.
Washington is fun to collect...I have a Monroe that only 80 were made. Fun that is until you need a dial for one...sadly few dials exist that are worth using, you'll usually have to "rob" one off another watch.
When I get a nice 19 or 21J Army and Navy with a half decent dial I will let you know
Tom Dunn...
TIME MACHINE
www.myrailroadwatch.com
June 19, 2013, 13:33
Peter Kaszubski
Tom and Dave thank you.
here is the dial picture.
June 19, 2013, 17:07
William D. White
I believe that Illinois made the Washington Watch Co. line exclusively for retailer Montgomery Ward.
William
June 19, 2013, 18:08
Edward L. Parsons, Jr.
That's correct David, and another Illinois department store private label was the Plymouth Watch Co., sold by Sears & Roebuck.
