Hamilton 992 with 4 ft.dial
https://ihc185.infopop.cc/eve/forums/a/tpc/f/1086047761/m/4653911587
April 14, 2015, 22:23
Roger Stephens
Just got this s/n 861749=1912 with 4 foot dial
with block HAMILTON on dial.From the year of manufacture I believe it should have a dial with
script lettering.What do you think?
Roger
c
April 14, 2015, 22:25
Roger Stephens
Movement
x
April 14, 2015, 23:04
Bila Wirriganwalters
My understanding is Roger that this type of font started somewhere close to the 1920's, your watch should have a dial with the Hamilton in script as you have mentioned not block font.
Cheers
April 14, 2015, 23:22
Nice movement, great collectible! My guess is that it was a replacement installed > 1920. Having 4 foot replacement dials would not require they be "old" script.
April 14, 2015, 23:25
Roger Stephens
That is what I also Bila.I pulled the dial thinking it might be a 3 ft.dial that someone had
installed on the movement but sure nuff it has 4
feet.I have been told that Hamilton made "replacement"dials for folks who might want
to upgrade to a different look.Maybe that is what happened here.
April 14, 2015, 23:30
Roger Stephens
David I guess we were both typing at the same time.Thanks for your input.Does that make this dial correct for this movement?
April 15, 2015, 07:53
Buster Beck
[quote] "I believe it should have a dial with
script lettering.What do you think?" [end quote]
You are correct Roger as the current dial on the watch would be an "upgrade/replacement" after the HAMILTON signature dials came out with the new font but still being made with 4 dial feet. It was designed as a replacement dial with the later font for the older movements that required 4 foot dials.
It would not be correct for your movement, but would be a later made, workable, replacement dial, as David said.
April 15, 2015, 17:24
Roger Stephens
Thanks Buster.
Roger
